unconfigure diffserv replacement
Description
Resets all DiffServ replacement mappings to the default values.
Syntax Description
N/A.
Default
N/A.
Usage Guidelines
Use this command to resest all DiffServ replacement mappings to default values.
The following command resets the DiffServ replacement mappings to their default values:
unconfigure diffserv examination
This command was first available in ExtremeXOS 11.0.
The ports keyword was first available in ExtremeXOS 12.2.2.
Platform Availability
